Activity Forums Adobe After Effects Replacing a single instance of a footage item
  • Replacing a single instance of a footage item
    Posted by Sofia Svensson on March 3, 2010 at 10:54 am
    This seems like it should be a basic function… and yet after much googling I can’t find out how to replace a single instance of a particular footage item.
    For example… I’ve used a JPG many times in a project and I need to replace it in only ONE of the places where I’ve used it (as opposed to the normal “Replace footage -> File” function which replaces the file in ALL the places I’ve used it).
    Can I do that? 🙂
    Katherine Landgrebe replied 16 years, 3 months ago 5 Members · 6 Replies
  • John Cuevas
    March 3, 2010 at 2:02 pm
    Sure-select the jpeg in the timeline that you need to replace. Hold down ‘alt'(pc) and select the new footage from the project panel. Now while holding down ‘alt’ drag it on to the old jpeg. It will replace the footage with keyframes,effects,masks all the same.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Sofia Svensson
    March 3, 2010 at 2:26 pm
    Ahaaaa! Knew there had to be a way. Hopefully the next time someone else can’t find a solution they’ll google this post.
    Thanks for your help!! 😀
  • Todd Kopriva
    March 3, 2010 at 5:03 pm
    searching After Effects Help with terms from your question brings up this:
    “Replace layer sources with references to another footage item”
    “1. Select one or more layers in the Timeline panel
    2. Alt-drag (Windows) or Option-drag (Mac OS) a footage item from the Project panel onto a selected layer in the Timeline panel.”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Erin Capparelli
    March 3, 2010 at 9:52 pm
    Perfect timing.. just needed the answer to this question as well. Thanks guys.
  • Katherine Landgrebe
    June 15, 2010 at 6:05 pm
    how about .ai or .eps footage? There the replacing function does not seem to work. Anybody know why or how I can work around this?
    I have imported an AI as a composition and would now like to replace the single layers with those of another AI aomp to keep the length and transparency settings etc.
    June 15, 2010 at 6:09 pm
    Erm, sorry, now it works just fine with my test files. Dunno what went wrong (or right in this case). Sorry for bothering. I’m happy for now!
