Activity Forums Adobe After Effects Replacing a photo in a comp without redoing attributes?
  • Replacing a photo in a comp without redoing attributes?
    Posted by Steve Morris on June 11, 2006 at 2:42 am
    I have a “3-D” animation in AE of a group of pictures that spin around a central point. I would like to make this animation somewhat of a preset. Something which I can quickly change the photos in the future. What is the best way of going about this? I was thinking of replacing the original photos on the hard drive with a different photo and keeping the file name. Is this possible?
    Markofcain replied 20 years, 3 months ago 4 Members · 4 Replies
  • Satesh Ramjattan
    June 11, 2006 at 4:01 am
    select the layer in the timeline, then select the new picture in the project and hold down ALT while dragging it onto the layer to replace it.
  • Julian Sixx
    June 11, 2006 at 5:18 am
    Hi
    …follow the steps as mentioned in the previous post.Instead of dragging the new clip,you could just hit CTRL+ALT+\
  • Steve Morris
    June 11, 2006 at 6:16 pm
    I tried the dragging method with great sucess. This will make things much easier. I will try cntrl + Alt + \ next time.
  • Markofcain
    June 13, 2006 at 2:17 am
    If you are using Windows version 6.5, and you prefer a “mousey” approach you can do this:
    In the Comp window Right Click the original photo to reveal the context sensitive menu and choose “Replace Footage –> File …”
    It’s great to have multiple paths to the same end.
    Mark Cain
    Sarasota, FL USA
