Activity Forums Adobe Premiere Pro replacing a .mov file with an image sequence?
  • replacing a .mov file with an image sequence?
    Posted by Bart Stevens on October 13, 2011 at 9:38 pm
    What I thought would be an easy task has become very frustrating.
    I have a 4k project, that I rendered 1/4 resolution proxy files.
    I did my edit with the proxy .mov files.
    I’ve got my edit done, and want to substitute my low rez .mov file with 4k DPX image sequence.
    I can substitute the first frame of the sequence with the .mov file, but no option of importing the sequence.
    I have tried other work arounds:
    – importing the 4K sequence and trying to do the substitute in my composition window. When I try this it doesn’t recognize the starting point of my cuts. It looks like it starts at the beginning of the footage instead of the cut “in” point.
    – I’ve also tried replacing the footage in AE, but again it’s not recognizing the correct place of the cuts.
    Footage is all interpreted at the correct fps.
    Micz Kicz replied 13 years, 12 months ago 2 Members · 4 Replies
  • Bart Stevens
    October 13, 2011 at 11:09 pm
    never mind – wrong fps in encoding proxy
  • Micz Kicz
    September 1, 2012 at 5:14 am
    Bart, can You please put more specific conclusion? I have exatly THE SAME situation as yours, but changing the interpreted fps in Premiere (both to final DPX sequence and MOV proxy) doesn’t help on the “in-cut” position issue.
    Generally both my fpses mach – both are interpreted as 25fps “on the start”. They are both created from the same RED files recorded in slow motion (it was 50 fps, as I remember) – but that should not be important really, right? Both the clips were to be played in 25 fps, and that’s the value they are interpreted with by Premiere.
    So what was your way of solving this hole problem of changed the “in-cut” position?
    Thank You in advance for Your time, to help me.
    EDIT: HERE YOU HAVE a video which illustrate the problem, step-by-step:
    https://youtu.be/ubS7mVZE4tc
    EDIT2: For all of you, who suffer from above ‘bizzaremente’ – the solution is as simple as SHIFT+ALT+drag, instead of ALT+drag. 🙂 That way the in and out points are preserved.
  • Bart Stevens
    September 4, 2012 at 3:36 pm
    I can’t be exactly certain, because it was a while ago, and currently my workflow is a little different. But I don’t think I was able to get around the “in cut” issue. I think I had to re-do my edit unfortunately. Sorry I couldn’t be more help.
  • Micz Kicz
    September 4, 2012 at 11:56 pm
    Thanks Bart for your respond. My situation has changed too – I have moved with my editing to After Effects (due to problems with replacing, mentioned above, and big amount of manipulations on the clips, which are better handeled in AE). But – just to close the case: You acctually can avoid messing-up the in-cut point in PR with SHIFT+ALT+DRAG, instead of ALT+DRAG
    Creative Creature 🙂
