Activity Forums Adobe Photoshop Replacing a label in a product image
  • Replacing a label in a product image
    Posted by Keith Vickers on March 22, 2023 at 11:39 pm
    Hi all
    I need to place new labels over the ones in images like the one below.
    Could any sage member tell me which Photoshop tool I might use to achieve this?
    I will be supplied with full labels which would theoretically stretch around the entire circumference of the object in the image.
    Thanks in advance.
    Hector Vera replied 3 years, 5 months ago 2 Members · 1 Reply
  • Hector Vera
    March 31, 2023 at 3:01 pm
    You can try using the Rectangle Tool to create the correct size for your label. Then after this, you can use the text tool to add what text you wish to add within the Rectangle Tool.
    If you wish to create a custom shape for your label, you can utilize the Type Mask Tool.
    I found this link that can help you with this: https://www.websitebuilderinsider.com/how-do-i-create-a-label-template-in-photoshop/
    After that’s all done, you can print out the label depending on the size and paper you are planning to use for it. Any further questions, let me know.
