Activity › Forums › Adobe After Effects › Replacing a color in a precomp? NOOB LEVEL
  • Replacing a color in a precomp? NOOB LEVEL
    Posted by Eric Chard on January 31, 2021 at 8:21 pm
    I’m going to have a precomp that will be used in 4 layers in the main comp. What’s the best way to replace a given color in the layers?
    (I should know this but it’s been a couple years since I used AE.)
    Eric Chard replied 5 years, 7 months ago 3 Members · 3 Replies
  • Walter Soyka
    January 31, 2021 at 11:12 pm
    I’m not sure I understand exactly what you’re getting at. You have a single precomp that you want to re-use multiple times, but you want to replace one of the colors for your different uses?
    There’s a new feature in Ae — essential properties — that makes this much easier than it used to be. Here are some helpful links:
    https://helpx.adobe.com/after-effects/using/essential-properties.html
    https://www.schoolofmotion.com/blog/master-properties-after-effects/
  • Liran Tabib
    February 1, 2021 at 12:10 pm
    Hi Eric
    Walter’s advice using Essential graphics is great, and will work in most scenarios.
    If you bump into trouble you can always use True Layer Duplicator to duplicate precomp hierarchy
  • Eric Chard
    February 3, 2021 at 7:27 pm
    Thanks Walter and Liran: I (vaguely) remember seeing a presentation at Adobe HQ on just this feature, but it had slipped my mind. A very helpful reminder, thanks.
    (Trying to use “Change Color” or whatever it is is NOT very much fun.)
