Activity › Forums › Adobe Premiere Pro › Replacement video card recommendations
  • Replacement video card recommendations
    Posted by Jon Doughtie on March 22, 2014 at 1:10 pm
    Guys this is a bit of a weird one, so hear me out.
    I am looking to replace the video card in my home system. I’m editing home stuff only on this unit, mostly NTSC SD content. The system is an old HP Pavilion d4790y, and the original video card (a GeForce 7600, I think) is outputting a lot of junk now – lines and spots and dots.
    I’ve been upgrading. OS drive is a 256GB SSD. Storage/video is a 2TB WD Black Caviar. OS is Win 8.1, with the Stardock software, so it can also look and run like Win 7. Just 4GB RAM. I think I can go to 8GB on this machine if I also load the 64-bit Windows version.
    Adobe suite is CS4. Old news, I know. Most usage is Premiere Pro, some light AE work, and of course Photoshop.
    I am looking at some the PNY cards with nVidia chipsets, and guessing most of the inexpensive ones will probably easily outshine the old GeForce 7600.
    With these parameters in mind, what features should I care about? Will CUDA cores matter with my older CS4 suite? Will the CS4 suite leverage higher RAM on the card? Your thoughts are appreciated.
    This is the last money on this system. The next upgrade will be a new machine. I know this one doesn’t owe me a thing; it only edits older SD personal stuff.
    Jon Doughtie replied 12 years, 6 months ago 2 Members · 2 Replies
  • Tim Kolb
    March 22, 2014 at 1:36 pm
    CS4 won’t actually use CUDA…that’s a CS5 (64 bit) and later feature. You can go with a pretty modest card and you won’t be depriving yourself of any processing power in Premiere Pro CS4.
    I would guess you could pick up last year’s basic GeForce card(more power efficient than a older used…) NiB for under a hundred bucks, and you’d be fine.
    You’re basically looking for a little bit of OpenGL support and the ability to light up the display.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Jon Doughtie
    March 22, 2014 at 5:26 pm
    Thank you Tim; I thought that was the case. I’ll worry about the rest when I replace the whole rig.
    And buy a used copy of CS6.
