Activity › Forums › Apple Final Cut Pro › Replace with Gap Multicam – FCPX 10.3.2 (Not possible)
  • Replace with Gap Multicam – FCPX 10.3.2 (Not possible)
    Posted by Stanley Sousa on January 25, 2017 at 3:22 pm
    Guys, I can not use “replace with gap” in fcpx 10.3.2 in multicam.
    This was possible in multicam in 10.2.3, and I used a lot to cut my marriages.
    In 10.2.3 I used “in” “out” to select, and cut with “Backspace”. In this way there was a space between the two clips, maintaining synchrony.
    Follow the video below comparing this feature in both versions.
    Andy Neil replied 9 years, 8 months ago 3 Members · 4 Replies
  • Andy Neil
    January 25, 2017 at 7:10 pm
    I was able to confirm your problem. I hadn’t used that feature before so I didn’t realize it’d been changed. I think you use the feedback menu to explain that both ripple and replace with gap should be possible in multicam.
    However, as a workaround, you can blade sections, select and delete. this will leave a gap in the multiclip. Also, the roll tool works so you can peel back clip edges and leave a gap as well.
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • Stanley Sousa
    January 25, 2017 at 10:48 pm
    Thank you Andy.
    Thanks for confirming that this is a bug.
    As you said, I am using the blade tool to cut, but I get higher speed using “in out” + Backspace.
    I’m sorry for English. I’m in Brazil
  • Mike Fitzsimmons
    January 26, 2017 at 5:17 pm
    Hey… If I’m understanding the issue correctly, In/Out + FORWARD DELETE (or SHIFT DELETE) will leave the gap.
    Hope this solves it…
    Mike
    \’Burbs of Detroit
  • Andy Neil
    January 26, 2017 at 5:21 pm
    [Mike Fitzsimmons] “Hey… If I’m understanding the issue correctly, In/Out + FORWARD DELETE (or SHIFT DELETE) will leave the gap.
    I’ve tried this Mike. It doesn’t work. I think this is because gap footage is a construct that can be selected (and added to a timeline via the replace with gap shortcut), but there is no “gap” footage in a multiclip. This seems to be a change from the previous version and I’m not really sure the point of it.
    Andy
