Activity › Forums › Adobe Premiere Pro › “Replace with clip” greyed out in Premiere CC17
  • “Replace with clip” greyed out in Premiere CC17
    Posted by Tom Tremayne on May 13, 2017 at 10:09 pm
    Hello,
    Any idea what could be causing this problem? I select the clip in my timeline and right click only to see that the “replace with clip” option isn’t available. It’s worked fine in the past so not sure what has caused this all of a sudden.
    Thanks in advance ☺
    Duke Sweden replied 9 years, 4 months ago 3 Members · 4 Replies
  • John Pale
    May 14, 2017 at 12:50 am
    Ignore post. I wrote something completely wrong and deleted it.
    Apologies.
  • Duke Sweden
    May 14, 2017 at 11:28 am
    Are you clicking on the clip you want to use in the bin to replace the clip in the timeline first? I’ve seen enough weird oddities that no one else has to know that’s probably not the problem, but who knows. Maybe you’ve had a brain fart and suddenly forgotten to do that before trying to replace a clip. Hope this helps.
  • Tom Tremayne
    May 14, 2017 at 9:09 pm
    Embarrassingly, yes that was the issue. The project bin wasn’t in my window. As soon as I brought it back in everything went back to normal. Thanks!
  • Duke Sweden
    May 15, 2017 at 12:29 pm
    10 points for Gryffindor!
