Activity Forums Adobe Premiere Pro replace with after effects composition grayed out!??
  • replace with after effects composition grayed out!??
    Posted by Laurence Loz on February 14, 2017 at 5:21 pm
    I have recently bought the creative cloud, had old versions of ae and pp previous but removed them prior (well at least I think so) when i right click on a clip in premiere the replace with after effects composition is grayed out… i notice i have dynamiclinkmediaserver . 7 folder in program files/common files… could it be possible this is an older version left behind?? i desperately to figure this out as i have a job to complete.
    Duke Sweden replied 9 years, 7 months ago 2 Members · 3 Replies
  • Laurence Loz
    February 14, 2017 at 8:48 pm
    i have everything and its all up to date??
  • Laurence Loz
    February 14, 2017 at 10:26 pm
    just uninstalled absolutely everything adobe related and went through my program files cleaning a ton of crap left behind from older versions, reinstalled, now its working! phew!
  • Duke Sweden
    February 15, 2017 at 3:56 am
    Did you install After Effects before you installed Premiere Pro? I remember that if you don’t install Audition before Premiere Pro, then “edit in Audition” will be grayed out. The program has to be installed first in order for Premiere Pro to see. Maybe that was the same problem you had with AE.
