Activity Forums Adobe After Effects replace with ae comp – wrong comp!
  • replace with ae comp – wrong comp!
    Posted by Jonny Webb on July 3, 2012 at 10:30 am
    hi, not usre if this a PPro ro an AE problem…
    In PPro i chose a clip and did Replace With AE Comp, and AE opens, i save the project, and go about doing my thing. Save it, close it. And back in PPro all is good.
    But now i open my AE project and do some more things – precomp, add some filters/effects to the new comp, etc. save it & close it.
    But PPro is not getting my ‘final’ comp – its stuck with the first comp, even though i’ve renamed the comps in AE.
    How to i make PPro take my final comp from the AE project.
    Thanks.
    Jonny Webb replied 14 years, 2 months ago 43,214 Members · 2 Replies
  • Jonny Webb
    July 4, 2012 at 9:00 am
    But i had finished with PP. The only thing left was to ‘fix’ one clip – the one replaced with AE.
    I tried to export the AE comp (lossless, avi) and then import it into the PP project. But this had too many problems, such as much lower quality, my fades (opacity 0%) were coming up as black, etc.
    It would be nice to use PP and AE as advertised.
    I just need PP to accept the final comp from AE.
  • Jonny Webb
    July 4, 2012 at 11:58 am
    yeah. done.
    The trick is…
    when you’ve finished in AE, save and close your project.
    go back over to PPro and File->Import->choose the AE project you’ve just done -> and PPro will show a list of compositions and let you choose one to import.
    So as long as you used a sensible naming convention, you can import the ‘final’ composition.
    It does seem odd that DynamicLink doesnt have any options/settings about which comp to bring back over, especially as the link names a project file “bla.aep”. And as i’ve just shown, PP does understand importing an AEP and gives a “which comp” window.
    Notes: what i actually see in PPro is the low quality proxy i made in AE. But after editing the AE comp again, PPro showed the realthing. However this may simply be because i was in AE so long PP had time to ‘conform’….
