Activity Forums Adobe After Effects Expressions Replace Text Expression
  • Replace Text Expression
    Posted by Matthew Tully on July 23, 2008 at 3:16 pm
    Howdy,
    Problem: I am loading text dynamically from an XML file to write credits for several artists using a script. When I pull the data into AE it keeps introducing a string of escaped code. I can’t seem to solve the broken code, but the string it dumps in is always the same, its a unicode value.
    Solution(i think): attach an expression to search for the escaped code in Source Text. Replace the unicode with another string of text using if/else.
    Questions: Here is loosely what I imagined using. How do I make it search and find just the one string?
    if (text.sourceText = “\xyz”) text.sourceText = “replaced” else (text.sourceText);
    right now this code would return “replaced” regardless of what is in the source text. So its totally broken. I understand why, but I don’t know how to tell it to find just one string in sourceText. Please help!
    Thanks in advance. This forum has helped me so many times!
    Mikhail Doroshenko replied 7 years, 4 months ago 5 Members · 11 Replies
  • 11 Replies
  • Lloyd Alvarez
    July 23, 2008 at 3:32 pm
    try this:
    text.sourceText.replace(/something to replace/gi, “what to replace it with”)
    -Lloyd
    https://aescripts.com
  • Lloyd Alvarez
    July 23, 2008 at 3:34 pm
    in case you are wondering what the gi stands for:
    search (g)lobally for the string and be case (i)nsensitive
  • Dan Ebberts
    You should be able to fix the problem in the script, but if not, this expressions should do it:
    text.sourceText.replace(/xyz/,”replaced”)
    Dan
  • Matthew Tully
    July 23, 2008 at 4:48 pm
    Thanks for the tips. Victory!
    You guys are awesome!
    Do either of you have any good resources for expressions that control text?
  • Dan Ebberts
    July 23, 2008 at 5:11 pm
    Any good JavaScript reference will have a section on string methods, which will be very helpful. It should also include a section on “Regular Expressions” (not related to AE expressions) which are used by some of the string methods.
    Dan
  • Matthew Tully
    July 23, 2008 at 8:47 pm
    Thanks again Dan!
  • Geoff Schultz
    April 5, 2017 at 7:27 pm
    How would I replace multiple strings of text?
    Currently I have:
    replace(“‚Äú”, ‘”‘)
    replace(“‚Äù”, ‘”‘)
    But it is only looking at the second string.
  • Dan Ebberts
    April 5, 2017 at 9:14 pm
    Try it this way:
    replace(/‚Äú|‚Äù/g, ‘”‘)
    Dan
  • Geoff Schultz
    April 6, 2017 at 7:22 pm
    what if I am wanting to replace multiple codes with different characters, like a quotation mark, apostrophe & an em-dash all on 1 layer of text?
  • Dan Ebberts
    April 6, 2017 at 7:35 pm
    I suppose you could do something like this:
    txt = thisComp.layer(“text”).text.sourceText;
    txt.replace(/”/g,”x”).replace(/’/g,”y”).replace(/-/g,”z”)
    Dan
