Activity Forums Adobe After Effects Expressions Replace Text before use Expression
  • Replace Text before use Expression
    Posted by Ron Grev on February 10, 2017 at 9:14 am
    Hy,
    I have a Text layer, that is expression drived.
    L = text.sourceText.length;
    It = time - thisLayer.inPoint;
    T = It*effect("Speed")("ADBE Slider Control-0001") - effect("Start After")("ADBE Slider Control-0001")*effect("Speed")("ADBE Slider Control-0001");
    F = Math.round( It % 1.2);
    if(F==1 |(T0)){Fl="|";}else{Fl="";}
    substr(0,T) + Fl
    Now i Want to replace the Text with the sourcetext of an other Layer.
    Just to link above:
    comp("Program title MASTER").layer("Neuer Text").text.sourceText
    doesnt work.
    So how can I replace the Text before the Expression is doing his job?
    Thank you!
    Beste Regards
    Ronald
    Ron Grev replied 9 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 10, 2017 at 5:10 pm
    I haven’t tested it, but probably something like this:
    txt = comp(“Program title MASTER”).layer(“Neuer Text”).text.sourceText;
    L = txt.length;
    It = time – thisLayer.inPoint;
    T = It*effect(“Speed”)(“ADBE Slider Control-0001”) – effect(“Start After”)(“ADBE Slider Control-0001”)*effect(“Speed”)(“ADBE Slider Control-0001″);
    if(F==1 |(T0)){Fl=”|”;}else{Fl=””;}
    txt.substr(0,T) + Fl
    Dan
  • Ron Grev
    February 12, 2017 at 7:51 pm
    Hy dan,
    thank you.
    txt.substr() is the key!
    RonG
