Activity Forums Adobe Premiere Pro Replace Source Footage with After Effects Comp
  • Replace Source Footage with After Effects Comp
    Posted by Rob Frese on August 27, 2014 at 8:37 pm
    Is there a way to replace all instances of source footage with a dynamically linked After Effects composition?
    I can replace a single instance of footage in a timeline by right clicking, “replace with clip” / “from source monitor” (if I put the AE comp in the source monitor before hand). But I’m trying to replace ALL instances of the clip.
    If I right click on the source clip in the project panel and go to “replace footage” I can only select other footage (selecting an AE project file results in a “general error” — no options to select an AE comp).
    If anyone’s familiar with AE, I’m looking for a Premiere Pro equivalent of the following behavior: in the project panel I can hold ctrl+alt and drag COMP A onto COMP B — this will replace all instances of COMP B with COMP A.
    I’m aware I can export the AE comp and import it, etc, but I’m trying to do with via dynamic link.
    Any help would be appreciated.
    Rob Frese replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
