Activity Forums Maxon Cinema 4D Replace selected Objects with new objects?????
  • Replace selected Objects with new objects?????
    Posted by Gregpro on March 27, 2006 at 4:26 pm
    Is it possible through C4D or any plugin on the market to replace a group of objects with another group of objects in the exact same spot? This is very puzzling for me. Any help would be greatly appreciated. Thank you.
    Greg
    Greg Serafin replied 20 years, 5 months ago 3 Members · 2 Replies
  • Brian Jones
    March 28, 2006 at 1:29 am
    use the built-in Transfer function, there are plugins too, Other Objects PSR comes to mind…
  • Greg Serafin
    March 29, 2006 at 2:58 am
    If you are talking about using stand-ins (as in, using a simplified model to set-up the animation and then replace it with the complex one for final rendering) try a plugin called something like “clone animation”.
    I remember having some luck with it a while ago. It will not clone deformers (but they can be copied from one object to another) or PLA animation, but the rest worked OK.
    The other way I deal with using stand-ins is to child a complex model to a skeletal version of it, make it invisible, animate the simple one (just to speed up the screen display) and for the final render make the simple one invisible and render the complex one.
    IQ
