Activity › Forums › Panasonic Cameras › Replace of Component cable
  • Replace of Component cable
    Posted by Michael Sacci on August 11, 2008 at 12:01 am
    Seems I have misplaced the analog component cable to my camera, does any know where i can purchase a replacement set and if anyone found a set with BNC ends instead of RCA?
    Adam Smith replied 18 years, 1 month ago 3 Members · 6 Replies
  • Christopher Wright
    August 11, 2008 at 4:02 am
    Comprehensive has just about any cable combo you could dream up. They also have very good quality cabling.
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows XP Adobe Studio CS3, Vegas 8.0, Lightwave 9.2, Sound Forge 9, Acid Pro 6, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
  • Michael Sacci
    August 11, 2008 at 4:49 am
    Don’t see the cable needed to go with the HVX200.
  • Michael Sacci
    August 11, 2008 at 5:11 am
    Looks like it is a Canon Cable
    https://www.bhphotovideo.com/bnh/controller/home?O=cart&A=details&Q=&sku=410327&is=REG
    Just wish I could find it with BNC ends on it.
    August 11, 2008 at 5:20 am
    If you don’t see it listed, Comprehensive will make any cable you want, just give them your desired I/Os. Or better yet, why not just order another cable directly from either Panasonic or a Panasonic dealer??
  • Michael Sacci
    August 11, 2008 at 5:43 am
    As stated above I found a replacement but I was really hopping someone knew of a place that sold BNC version (already made).
  • Adam Smith
    August 11, 2008 at 4:29 pm
    [Michael Sacci] “I was really hopping someone knew of a place that sold BNC version (already made).”
    Yeah.. it’d be nice to skip the adapters and go straight to BNC. If you find one, post it here.
    I’m wondering if the D-connector clamps are loosening on my cable, I haven’t used it a lot but lately it doesn’t seem to hold tight enough, I have to loop the cable up and over the camera body to keep the tension or the weight of the cable will move the connector and cause the signal to drop out. =(
    Video Photographer / Avid & Final Cut Editor
