Activity Forums Media 100 Replace Media?
  • Replace Media?
    Posted by Ben Masterson on June 16, 2010 at 9:02 pm
    I edited a program in M100 Suite 1.5 and used a demo version of some audio for it to see if it would work. I ended up with a lot of edits and such in the audio, and I now need to replace the demo version with the purchased version. It is exactly the same only there is no watermark on it. I can’t seem to be able to replace the media. I have tried importing the new sound file, then deleting the original scratch_audio-T1_A1.mov and scratch_audio-T1_A1.mov.
    Then I renamed the newly created media in the Media folder to the old names. It doesn’t find them. It does however find the old ones if I don’t delete them, even when they are on another drive and renamed….it still wants to point to these. Is there any way to do this, or am i going to have to re-edit all the music?
    (I can export the program to After Effects, then replace the audio media that way and render it…however then it becomes flattened and I would rather keep my nodes.
    On similar note, is there anyway to “Batch Reaquire” quicktime movies? Like if I had a quicktimes rendered from aftereffects on the timeline, then updated and re-rendered the quicktimes (all the same length etc.), can I relink them?
    Thanks.
    -Ben
    Floh Peters replied 16 years, 3 months ago 2 Members · 1 Reply
  • Floh Peters
    June 16, 2010 at 9:23 pm
    This can be done relatively easily, but not automatically. You can drag a clip onto another one while holding CTRL and Command to get the optons what to replace. You would want to replace audio media only.
    The approach would be: double-click your clip on the timeline, Copy the Mark In TC, double click the new clip and paste mark in. Then Command-drag on the old clip on the timeline. Move to next clip…
