Activity Forums Apple Final Cut Pro Legacy replace media
  • Posted by Nathan Halder on October 28, 2010 at 9:35 pm
    I have brought a PSD file onto the timeline. When I try to click it in the timeline to open it in the browser window, it wants to open in a new tab. If I click it once, and go to motion, the speed ramps from 0 to 100 but I can’t delete the keyframe.
    Also, and here’s the biggest problem, I can’t use keyframes to manipulate the size of the graphic. It’s a simple logo and I want to have it slowly get bigger over a few seconds. I can do this with photos and video, but the PSD won’t let me. Thanks for any advice.
    Nathan Halder replied 15 years, 10 months ago 3 Members · 3 Replies
  • Andy George
    October 28, 2010 at 9:58 pm
    Try Right Click or CMMD Click and select open in viewer. That will get you access to the position property.
    -Andy George
    Senior Editor
    http://www.chiselindustries.com
  • Bret Williams
    October 28, 2010 at 10:01 pm
    The PSD comes in as a layered sequence. Double clicking it opens the sequence. It’s a feature, not a bug. If you don’t need the layers, save your psd as a png and it’ll retain all the transparency.
    If you like the sequence in a sequence, you’ll have to option+double click to open it in the viewer and then manipulate.
  • Nathan Halder
    October 28, 2010 at 10:18 pm
    Thanks to both of you – that worked! Sorry about the subject line – old post. Cheers.
