Activity Forums Adobe After Effects Replace materials on 3D objects brought in to AE CS4?
  • Replace materials on 3D objects brought in to AE CS4?
    Posted by Eric Goldstein on January 8, 2009 at 5:46 pm
    Is it possible to replace materials on scenes generated from 3D aps in AE (CS4). I’ve been able to separate 3D objects using IDs for depth of field, fog, etc. But can you actually replace materials on the objects? This was possible in Combustion.
    I’ve also seen a product called RE: Map. Is this plug-in necessary to acomplish replacing materials? Does it work?
    Any thoughts/guidance are greatly appreciated.
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 17 years, 8 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    January 10, 2009 at 12:00 pm
    Not too sure if it can be done without Zaxwerks. For Re.Map, send Pete an emaill via their site. He’s normally pretty quick with replies.
    Good Luck
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Eric Goldstein
    January 14, 2009 at 11:15 pm
    Hi Roland,
    Thanks for your thoughts. I’m checking out the Zaxwerks
    products now.
    Eric
    Eric Goldstein
    Los Angeles
