Activity › Forums › Adobe Premiere Pro › Replace Master Clip With After Effects Composition?
  • Replace Master Clip With After Effects Composition?
    Posted by Brad Bussé on August 14, 2014 at 10:32 pm
    Is it possible? I like the new 2014 feature allowing FX to be applied to master clips. However, I have some multi-cam green screen interviews that I would like to key using Keylight in Ae instead of Ultrakey in Pr. I can process master clips in Ae and relink to those in Pr, but it would be easier if I could convert the master clips to Ae sequences directly from within the bin.
    Jimmy Valentine replied 11 years, 3 months ago 3 Members · 2 Replies
  • Alex Udell
    August 15, 2014 at 9:10 am
    What if you reveal the clip in the Finder (or Windows OS)…
    Bring it manually into AE
    Pull the Key
    Output new file.
    Make off line and then relink media of master clip in ppro project to keyed output file from AE?
    no idea if this will work…but worth a shot…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Jimmy Valentine
    June 9, 2015 at 2:37 am
    It would make a lot of sense for the people using Ae for color correction.
