Activity › Forums › Adobe Photoshop › replace layers in PS
  • replace layers in PS
    Posted by Anthony Dupsta on November 7, 2012 at 12:09 am
    I have a large resolution 10k logo I have rendered in C4d.
    I have 6 passes that I bring into PS. I duplicate a few, use composite modes, layer masks and diff opacity values per layer. So I basically comp it in PS. No beauty pass.
    After I have created this template in PS. I have 5 more logos to render that have small variations. Just the text changes.
    However…When I render out the next logo, I can not simply replace the 6 layers in PS
    I have tried converting the layer to a smart object. The layer mask, opacity and composite mode get baked all together. And when I did replace the old diffuse with the new diffuse pass. The scaling is off all my layer masks are gone I have to re scale and transform the pass. Should just snap in there as it is the same resolution and nothing has changed?
    I can not find an easy solution to do all this redundant work per layer. I have to manually replace each layer, re do each layer mask and than line each pass up so they are not off center.
    I normally do this all in AE, do all my comping, hit replace footage..bamm done..but the resolution seemed like a job for PS.
    Please give me some good tips for this pipeline.
    Anthony Dupsta replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
