Activity Forums Adobe After Effects Replace layer to out time other layer at keyframe moment
  • Replace layer to out time other layer at keyframe moment
    Posted by Sander Van pelt on November 3, 2020 at 12:42 pm
    Hello everybody,
    I have multiple layers (photo’s). The one appears as the other disappeared. I want to change this so I added opacity keyframes. And I want to overlap these layers.
    Suppose each layer lasts 3 seconds. It is completely invisible when it starts and after 0.8 seconds the opacity is 100%.
    So what is the quickest and easiest way to get the top layer to start 0.8 seconds before the bottom layer ends? So if the opacity of the layer is 100%, the layer below will stop.
    Is there a fastkey to move a layer based on the keyframes time (and not the In or Out time) to the end time of another layer?
    Thanks for your help
    Sander
    Michael Szalapski replied 5 years, 10 months ago 2 Members · 1 Reply
  • Michael Szalapski
    November 3, 2020 at 7:44 pm
    AE’s sequence layers command should do exactly that. You can even have it set your opacity keyframes for you.
