Activity Forums Adobe Photoshop Replace image function in photoshop?
  • Replace image function in photoshop?
    Posted by Mikkell Khan on January 28, 2010 at 1:26 pm
    Hi, let’s say you have a collage with pictures of different sizes, shapes and orientation. Now you’d like to change one of the pictures to a different one whilst maintaining the attributes of the one you will be replacing so it fits snugly in place for the collage.
    I know after effects has an easy way of doing this with a ‘replace footage’ function, however, is there such a way to do this in photoshop?
    Thanks for any quick and helpful responses on this matter.
    Mikkell Khan
    Director
    Diamond Films Ltd. (Trinidad and Tobago)
    Tiffany Terry replied 11 years, 2 months ago 3 Members · 4 Replies
  • Mikkell Khan
    January 29, 2010 at 1:51 am
    Anyone? Anyone at all?
    Mikkell Khan
    Director
  • Mikkell Khan
    January 29, 2010 at 6:46 pm
    Never mind. I found that once you ‘place’ an image, and then right click on its layer, you will see an option to replace image…
    Hope this helps anyone else who would want to know.
    Mikkell Khan
    Director
  • Theo Van laar
    February 1, 2010 at 11:26 am
    “Never mind. I found that once you ‘place’ an image, and then right click on its layer, you will see an option to replace image… “
    Even when you did not PLACE the image, you can do this. In that case you first context-click on the layer and select CONVERT TO SMART OBJECT. Then context click again on the same layer and select the REPLACE option.
    Theo
  • Tiffany Terry
    July 10, 2015 at 9:27 pm
    I was trying to figure the same thing out when I ran across your post. I tried that, but in my case it was easier in the end to just hide the old picture and add the new one in its place. I can always delete the layer that contained the old image if I feel like it. We used to use Photoshop to create our department flyers… it’s way too complicated for our needs, so we’ve since moved to In Design. I had to edit an existing flyer for an annual event, since I didn’t want to create the wheel just to change a little bit of text and the new presenter’s picture, LOL!!
    Good luck to everyone else! Photoshop is not the most intuitive program in my opinion.
