Activity Forums Adobe Premiere Pro Replace Footage with subclip or sequence possible ?
  • Replace Footage with subclip or sequence possible ?
    Posted by Andy Milne on January 6, 2013 at 9:44 pm
    I have a project which I edited with a low res file then got the hi res file from the client. The low res was an excerpt from the original clip so longer duration and different start point. This is ex HDV and there is no time code reference on the clips.
    I know how to replace a clip with another clip but in this case I need to either make a subclip of the hires and then replace the low res clip with that or make a sequence to length then replace the low res clip with the sequence but I can’t see that option. When replacing clips there is only the option to replace with another source file nit from within Premiere.
    The only solution I can see is the export the hires to length then reimport as a clip but this seems a bit cumbersome with the potential to loose quality in the process.
    Cheers
    Andy
    Andy Milne replied 13 years, 7 months ago 1 Member · 1 Reply
  • Andy Milne
    January 8, 2013 at 8:17 pm
    Bump.
    Has anyone had a similar problem with replacing clips with subclips?
    Cheers
    Andy
