Activity Forums Adobe After Effects Replace Footage Script
  • Replace Footage Script
    Posted by Davis Lindsay on April 25, 2012 at 6:53 pm
    Hello,
    I’m trying to create a script that will duplicate my _template comp, replace footage in the comp with another item in my movs folder. Then repeat this process until all movs have their own comps .
    my file structure:
    project
    comps
    _template
    movs
    lastname_firstname_asset
    so far I have…
    var proj = app.project;
    proj.item(1).item(1).duplicate();
    proj.item(1).item(2).replaceSource(proj.item(2).item(2));
    proj.item(1).item(2).name = proj.item(1).item(1).layer(3).name;
    I’ve realized replaceSource is used for c:// drive destinations.
    What other method could I use?
    Erik Waluska replied 14 years, 4 months ago 3 Members · 3 Replies
  • John Cuevas
    April 26, 2012 at 11:06 am
    I think you will get a better response on the expressions forum, some of the guys of over there are familiar with scripting.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Davis Lindsay
    April 26, 2012 at 1:55 pm
    Thanks John,
    I’ll post in expressions.
    Prepare for today and you’ll survive, prepare for tomorrow and you will thrive.
  • Erik Waluska
    April 27, 2012 at 5:29 pm
    There’s a script called “compsfromspreadsheet” on aescripts.com that does that. You just fill in the filenames and text, etc. on the spreadsheet and it replaces everything and creates new comps from your template comp. I’ve used it a few times and it works great, but you have to be careful about spelling, capitalization, etc. because it will stall on any errors.
