Replace Footage: Replace SD with HD. -Exact footage.
Hello all, I’m new here and have not found an exact answer to this in the forums. On a big time crunch and would appreciate any help!
My video project used 6 different cameras. This was an all day event and thus I have a lot of footage. I had someone pull the video from a P2 card and send it to me as one long video of all of the footage from that 1 camera.
I began cutting and organizing it into smaller sections before realizing the person had reduced it from 1280×720 to 720×480, AFTER I had done a large portion of the work.Q: I have the original downloading. The footage files are identical aside from resolution. If I “Replace Footage” in the bin, will it update all of the individual clips I created from that original lower res. version? It will be extremely time consuming if I have to go back and chop it all again.
Hope I am clear with my dilemma. I will continue editing while this 23GB file downloads if this works like I’m asking. That way I can essentially finish the video and simply replace with HD.
Thank you!
cbkyro
