Activity Forums Adobe Premiere Pro Replace footage in timeline, Prem Pro 1.5
  • Replace footage in timeline, Prem Pro 1.5
    Posted by Pedigree-punk on May 18, 2006 at 8:13 am
    Is there a ‘replace footage with’ function available in Prem Pro 1.5 anywhere? I want to replace clip in the timeline with an alternative source (can do it in AE no problem)
    TIA
    The destination is not important..its the journey that matters.
    Pedigree-punk replied 20 years, 4 months ago 3 Members · 3 Replies
  • Chris1621
    May 18, 2006 at 1:13 pm
    Hello,
    Not sure if the Replace Function is in Premiere1.5 but I suppose you could always just replace the original source file with the same name?
  • Jeff Bellune
    May 18, 2006 at 1:27 pm
    Or, you can use the Project>Unlink Media command in PPro 1.5 (it’s called Make Offline in PPro 2.0). It will make the current asset show up in the Project window as offline. Once it’s offline, you can relink it to the new media.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Pedigree-punk
    May 18, 2006 at 4:24 pm
    aha! Thanks for both sugestions, very helpful.
