Activity Forums Adobe After Effects Replace footage function is moving the layer
  • Replace footage function is moving the layer
    Posted by Matt Gerard on August 10, 2011 at 7:22 pm
    I am trying to replace a QT movie in a sequence with a different clip using the OPTION (ALT) + Drag method. Problem arises because the TC in the clips are different, so the new clips skooches down in the timeline to a different spot. Sometimes its a few seconds, sometimes its a few hours. Then I have to manually reposition the clip, move all the keyframes and trim it again. Is there any way to get AE to ignore the TC in the new clip?
    Matt
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow…
    Matt Gerard replied 15 years, 1 month ago 2 Members · 2 Replies
  • Stefan Hinze
    August 10, 2011 at 9:38 pm
    hey,
    it´s just a gues: i´d would try to precomp the clip – then set the compSettings to match the destination-comp, then alt-drag.
    i would be interested to hear if it works!
    (take a step back, to see the bigger picture)
  • Matt Gerard
    August 11, 2011 at 1:17 pm
    Hey all, I didn’t try the precomp thing, as I didn’t want to get into precomps for these simple sequences.
    Dave- This trick worked for the most part, the only problem is that the keyframes are locked relative to the layer, so when I hit the left bracket to move the layer to the correct time on the timeline, the keyframes would slide out of sync. So, to fix that, after I moved the new layer to the correct time, I put the playhead at the first keyframe of the old layer, hit u to expose the keyframed properties of the new layer, highlighted the properties, then hit command X then command V to cut then paste the keyframes to the correct time in the seq. Worked slick.
    Then I got smart and created a new comp, copied and pasted all the stuff from the old comp into the new one, and I was able to replace the footage properly without going through all the above BS. It was something in the comp that was goofing it up.
    Sheesh…
    Matt
