Activity Forums Adobe Premiere Pro Replace edit with timecode sync
  • Replace edit with timecode sync
    Posted by Ihab Ali on April 20, 2013 at 10:35 pm
    I’m having trouble with replace edit where I want the in/out point of the new clip to match the in/out point of the clip on the timeline timecode wise. Using Alt-drag to replace obviously doesn’t do that since it puts the in point at the begning of the new(replacing) clip. Using Shift-Alt drag was what I thought would achieve what I’m trying to do instead it either sets the in/out point at shifted point on the new clip or says “not enough head material to match frame”.
    I’m basically trying to process clips from the edit in AE, render the parts I’m using in the edit(by looking at the in/out timecode in PPro) plus a few handles and then replace the original clips in PPro for finishing.
    Any idea what I’m doing wrong?
    Ihab Ali replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
