Activity Forums Apple Final Cut Pro Legacy Replace edit with sync issues
  • Replace edit with sync issues
    Posted by Jason Mckee on December 10, 2009 at 2:20 am
    We are using footage captured from hdcam tapes (ProRes 422) and syncing it with audio WAV files. Because the audio files are longer on both ends than the video the merged clip has black with audio at the end an begining. This is not a problem when editing, but becomes when when trying to replace edit.
    The editor puts the cursor in the viewer were he wants the edit and then in the timeline he puts the cursor were he wants and then tries to do a replace edit. When using a clip that has been merged it does one of two things or both; It puts the clip in, but the clip is several seconds off of were it should be or the sound becomes out of sync from the video.
    If we make a supclip of the file we can use the replace edit function fine. The only reason that we do not want to do this to every clip is because we have several thousand and the editor has already used many of them so we can’t mess with some of them.
    I know it’s a long shot, but if there is a way to modify the clip without changing the timecode it would help us out greatly (the video timecode is what final cut is using and it matches our burn in perfectly).
    Our project is 23.976 Psf, and we are using Final Cut Pro 6.0.6.
    Thanks in advance.
    Matt Lyon replied 16 years, 8 months ago 2 Members · 1 Reply
  • Matt Lyon
    December 10, 2009 at 6:04 pm
    Hey Jason, what exactly do you mean by “modify the clip without changing the timecode”? I’m not sure what kind of modification you’re trying to achieve.
    If your editor marks an IN and OUT on the timeline before doing a “replace” edit, does the behavior you describe change? FWIW, I find the replace edit function to be somewhat kludgy. You may also want to play with marking just audio or just video edit points and see if that helps as a workaround.
    I don’t have any footage with properties like you describe, so I have no way to test it myself, but I’m just tossing some ideas out here 🙂
    Hope this helps,
    Matt Lyon
    Editor
    Toronto
