Activity Forums Adobe After Effects Expressions Replace decimal zero’s with dash
  • Replace decimal zero’s with dash
    Posted by Gerben Greuliker on November 14, 2022 at 9:48 am
    I’ve got an expression that generates numbers to currency.
    when the amount is a round number with “,00”, is it possible to replace the zero’s with a dash?
    I’ve got the following expression working:
    v=thisComp.layer("Grocerylist#1.csv")("Data")("Outline")("KidsCost")("KidsCost 4")
    new Intl.NumberFormat('nl-NL', {
    style: 'currency',
    currency: 'EUR',
    useGrouping: true
    }).format(v);
    Filip Vandueren replied 3 years, 10 months ago 2 Members · 3 Replies
  • Filip Vandueren
    November 14, 2022 at 10:48 am
    Dag Gerben,
    try this tweak:
    style: 'currency',
    currency: 'EUR',
    useGrouping: true
    }).format(v).replace(/00$/gi,"—");
    Don’t worry about the $, in this case it doesn’t mean a dollar, but 00 “at the end of a string”, so € 100,00 doesn’t become 1–,–.
    just using .replace(“,00”, “,–”) could work too actually.
  • Gerben Greuliker
    November 16, 2022 at 8:39 am
    He Filip,
    Thnx again!
    In the meanwhile I did find the ‘replace’ function but dit not know where to place it in the expression. Now when I see it it makes total sense 😄.
    As a sidenote: the top expression works, the bottom version not.
    Response is:
    Error: Syntaxerror: Invalid or unexpected token
    The second quotation mark after the zero is blue. Adding a space doesn’t solve it.
    Gr G
  • Filip Vandueren
    November 16, 2022 at 2:16 pm
    Yes, I didn’t put that in a code-block, so the wordpress layouter changed the quotes to curly brackets, this gives an error when copy-pasting…
    This is what it could have been:
    style: 'currency',
    currency: 'EUR',
    useGrouping: true
    }).format(v).replace(",00",",—");
