Activity Forums Adobe After Effects Replace comp – or something simular
  • Replace comp – or something simular
    Posted by Anders Carlsson on March 16, 2010 at 10:56 am
    Hi all,
    I’ve recently been in a situation were several artist are working on the same shot. One person on keying, one on roto, one on comp and so on.
    I would like the person that comps the elements together to start working with temp keys, and temp rotos, and then be able to switch them out as the project goes along. I don’t want to render out the elements, I want the compositor to import the key comp so he can have some flexibility if he needs it.
    Is there a way to “replace comp”, almost like the replace footage button, without having to import the project again and manually switch out the comp and delete the old stuff and so.
    Dynamic link between AE and AE?
    Michael Szalapski replied 16 years, 5 months ago 2 Members · 3 Replies
  • Michael Szalapski
    March 16, 2010 at 2:01 pm
    One possibility is that when an artist finishes their work on a shot, they select the composition they’re working on and choose the reduce project option. It removes everything from that project that doesn’t have anything to do with that comp.
    (I would suggest saving this as under a different file name, just in case.)
    Using this method, when your final guy is putting everything together and he imports that project, all he’ll get is the stuff that artist was working on.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Anders Carlsson
    March 16, 2010 at 2:48 pm
    Yes that is an option, but then I manually have to replace the comp and make sure the new one gets the same properties, (masks, effects) as the temp one.
  • Michael Szalapski
    March 16, 2010 at 4:11 pm
    [Anders Carlsson] “but then I manually have to replace the comp and make sure the new one gets the same properties, (masks, effects) as the temp one.”
    Select the temp comp and alt-drag the finished comp from the project window onto it.
    – The Great Szalam
