Activity Forums VEGAS Pro replace clips
  • replace clips
    Posted by John Culleton on September 12, 2012 at 10:17 am
    is there a quicker option to ‘replace clips’?
    i want to keep all effects and drop different clips into the timeline
    John Culleton replied 14 years ago 4 Members · 7 Replies
  • 7 Replies
  • Aleksey Tarasov
    September 12, 2012 at 12:05 pm
    Open Project Media window, select a file, right click and choose Replace
    Is this what are you looking for?
    Vegasaur – automation plugins and tools for Sony Vegas Pro
  • John Culleton
    September 12, 2012 at 12:18 pm
    is there another way? i was hoping to do it direct from the timeline instead of from the bin
  • Aleksey Tarasov
    September 12, 2012 at 12:27 pm
    idk another way to “replace clips” (w/o scripts)
    but perhaps you want the following: drag a new clip with the right mouse button and drop it on a source event and choose Add as Takes
  • John Rofrano
    September 12, 2012 at 12:29 pm
    [John Culleton] “is there another way? i was hoping to do it direct from the timeline instead of from the bin”
    No, the timeline contains “Events” that can hold multiple clips as Takes. The only place you deal with a single clip is in the Project Media.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • John Culleton
    September 12, 2012 at 12:56 pm
    thanks Aleksey, that’s much quicker 🙂
  • Sam Caino
    September 13, 2012 at 6:42 pm
    You could trick Vegas by closing the project, altering the file name of the original clip, then changing the file name of the new clip to what the old clip was originally called. Then when you reopen Vegas, it will automatically use that new file in place of the old one. However, this will affect all events on the timeline that use that piece of media.
  • John Culleton
    September 13, 2012 at 7:32 pm
    very slow option Sam, Aleksey’s is the best way…
    ‘drag a new clip with the right mouse button and drop it on a source event and choose Add as Takes’
    simple 🙂
