Activity › Forums › Apple Final Cut Pro Legacy › Replace clip (not replace edit)
  • Replace clip (not replace edit)
    Posted by Naveen Mallikarjuna on April 5, 2011 at 5:35 pm
    Is there a way to replace a clip with another clip? I’m not talking about the process of going through a replace edit.
    I have a spot done in HD, then resized to SD. So in my project, I have both the HD and SD version of the spot. The SD version of the spot is sitting in the sequence. Is there a way to just select the one sitting on the sequence, then select the the HD version sitting in the browser, and hit something that will swap the two? So that the HD version will now be in the sequence.
    This can easily be done in, say After Effects. Does FCP have the ability to do the same or do I have to go through the cumbersome process of a replace edit?
    Naveen
    Naveen Mallikarjuna replied 15 years, 5 months ago 2 Members · 2 Replies
  • Chris Tompkins
    April 5, 2011 at 6:10 pm
    You can COPY the new clip.
    Select old clip to be replaced.
    Cntrl Click on the old clip.
    Choose paste attributes.
    Select contents. I believe it is. Not in front of edit @ the moment.
    Going from HD to SD – you might need to further adjust something like distort or scale.
    Chris Tompkins
    Video Atlanta LLC
  • Naveen Mallikarjuna
    April 5, 2011 at 6:21 pm
    Thanks. This kind of does it, but it’s still not as easy as what’s in After Effects or Premiere Pro.
    FCP is supposed to be superior app for editing — not sure why something that simple is missing, though this isn’t the first time I’ve had that experience with FCP.
    Naveen
