Activity › Forums › Apple Final Cut Pro Legacy › Replace clip and leave effects?
  • Sean Lander
    October 25, 2005 at 11:41 am
    Two ways of doing this.
    1. Select the clip and hit copy. Use REPLACE to edit in the new shot. Right click on the clip and hit PASTE ATTRIBUTES and select Filters Motion etc.
    2. Open clip you want to insert in the viewer. Mark it up. Hit COPY. Go to old clip in timeline and right click on it and select PASTE ATTRIBUTES and select Content.
  • Steve Eisen
    October 25, 2005 at 2:40 pm
    When using Replace Edit, make sure there are NO In or Out points set on your timeline. Your playhead and the footage in the viewer determine what and where will be Replaced. Once you figure it out, Replace edit is a great tool.
    G5 Dual 2.5 160GB System 400GB Media Drive ATI 9800 256MB 6 GB RAM
    Dual Gig Quicksilver 1GB RAM 80 GB System drive (3) 250 GB internal media storage
    15″ Al Powerbook 1.25 1GB RAM
    OS 10.4.2 FCP 5, DVDSP 4, QT 7.02, Boris Red 3GL 2.45 TB External Stor
