Activity › Forums › Apple Final Cut Pro Legacy › Replace Clip…
  • Replace Clip…
    Posted by Dan Nethery on May 9, 2008 at 4:59 pm
    In After Effects I can select a clip in the timeline, then click and drag a clip from the bin wile holding ALT and drop it on the selected clip in the timeline. It will replace the clip and keep all of the effects and setting from the old clip.
    How do I do that in FCP?
    Thanx, dan.
    Andy Mees replied 18 years, 4 months ago 5 Members · 5 Replies
  • Tom Wolsky
    May 9, 2008 at 5:05 pm
    Load it into the Viewer and press F11.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Dan Nethery
    May 9, 2008 at 5:15 pm
    I Would like to post a Public Announcement.
    Tom Woisky is a genius.
  • Stacy Formby
    May 9, 2008 at 5:37 pm
    Make sure you’ve changed your Expose settings first if you want to use F11. Otherwise, all your windows will go whooshing away. (Clicking the blue Replace edit squares or dragging the new clip to the Replace overlay on the Canvas works as well).
  • Kevin Monahan
    May 9, 2008 at 6:01 pm
    Take his class or read his book. Then you will really be in the zone.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Andy Mees
    May 10, 2008 at 1:59 am
    for extra credit take note that F11 disregards marked in and outs, it works on playhead position replacing the clip under the playhead in the timeline with the clip in the browser so that the two playhead positions match up
    more of the same goodness can be found with the venerable copy/paste functions
    select the source clip and press cmd c to copy
    then choose the target clip press opt-v to paste attributes and select video content and/or audio “content” (and whatever other attributes you may want to bring from the original)
