Activity Forums Adobe After Effects Replace all instances of Comp A with Comp B inside the project window?
  • Replace all instances of Comp A with Comp B inside the project window?
    Posted by Chris Biagi on February 9, 2019 at 8:35 pm
    First post, hi!
    I have a project that is the result of importing several similar AE projects into one master project. There are a ton of redundant assets in these imported projects, and they were not very well structured by the original creator; as a result I have 20+ identical instances of “Comp A” in the project. These precomps are subsequently used in many other compositions. Each iteration of “Comp A” is used in a few different parent compositions.
    I would like to consolidate this so there is only a single “Comp A” source used in all of the parent compositions mentioned above. I’m aware of the technique of alt / option dragging the replacement “Comp B” onto a “Comp A” layer within a sequence. However this technique requires me to do the replacement for *every* of the dozens of places “Comp A” is used across the entire project.
    Question: Is there a way to replace ALL of the “Comp A” instances with “Comp B” within the project window? I basically want the same effect as “replace footage,” but I’m not sure how to do this with precomps.
    Eric Santiago replied 4 years, 12 months ago 4 Members · 4 Replies
  • Walter Soyka
    February 10, 2019 at 2:41 am
    [Chris Biagi] “Question: Is there a way to replace ALL of the “Comp A” instances with “Comp B” within the project window? I basically want the same effect as “replace footage,” but I’m not sure how to do this with precomps.”
    Yes! It works just like Alt-dragging to replace footage. Hold down the Alt key, then drag the Comp B project item on the Comp A project item.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Chris Biagi
    February 14, 2019 at 6:49 pm
    Ha! I must have been doing something wrong – I thought I had tried that method, but it kept putting the dragged comp inside the other comp, as a new layer. Thanks!
  • Mikael Holmström
    September 23, 2021 at 12:32 am
    This sounds great, but I can’t figure out what I’m doing wrong: why it keeps putting the dragged comp inside the other comp, as a new layer? /Mikael
  • Eric Santiago
    September 23, 2021 at 1:08 pm
    Did you open the Composition Flowchart and attempt that?
    Make sure the Alt/Option-drag it to the top layer source.
