Activity Forums Maxon Cinema 4D Replace a merge object
  • Replace a merge object
    Posted by Kurisuta Vd wilk on January 31, 2013 at 10:37 am
    I have all kinds of animated objects in a scene. On the objects are extrude nurbs placed, from splines out of illustrator.
    I want to have the same animated sequence, but with different splines merged. Is there a posibility to just replace the spline files ?
    So it will have the same keyframes and position etc. ?
    Adam Trachtenberg replied 13 years, 7 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    January 31, 2013 at 5:06 pm
    Sure, no problem as long as the splines themselves aren’t animated.
  • Kurisuta Vd wilk
    February 1, 2013 at 9:41 am
    Well, ok. Nice that it is possible.
    But ofcourse my question is How to do it.
    I mean replace.
    I don’t mean, delete the original and place a new one.
    Like you can replace a source file in After effects for example, so it takes over all properties.
    No knowledge is a Statement
  • Adam Trachtenberg
    February 2, 2013 at 4:43 am
    Ah, of course that’s your question! I foolishly assumed that the question you actually asked was your question. 🙂
    In this case simply dropping in a new one and deleting the old one is probably the quickest way to go about it. You could use an xref object to reference a Cinema file containing your spline, and then change the reference to another file containing a different spline, but that involves more steps than simply importing and replacing.
