Activity Forums Apple Final Cut Pro Legacy Repeating Transitions – Workflow
  • Repeating Transitions – Workflow
    Posted by Josh Haggard on July 15, 2011 at 7:19 pm
    I am editing sports footage.
    Lets say the main video and the replay footage is on V1.
    Every time there is a replay I have to do the following:
    Add a replay graphic on V2 for the entire replay clip duration
    Add an in graphic on V3 that covers the cut to from the main footage to the replay
    Add an out graphic on V3 that covers the cut from the replay back to the main footage
    See the screenshot below for a visual explanation.
    Is there anyway to automate this process, or at least simplify it in some way so I don’t have to manually place each of these elements. There are a lot of replays and this becomes very time consuming.
    Thanks.
    Josh Haggard replied 15 years, 2 months ago 2 Members · 2 Replies
  • Karen Cerino
    July 15, 2011 at 7:47 pm
    Try putting the replay and transition graphics into a nested sequence. Make the sequence around 15 seconds or so, depending on your average length of replays. Add markers to line up the in an out cut points. Adjust end graphic timing as needed.
  • Josh Haggard
    July 17, 2011 at 5:50 pm
    Worked perfectly – thank you
