Activity Forums Adobe After Effects Repeating Text with Text Sourced from Another Layer
  • Repeating Text with Text Sourced from Another Layer
    Posted by Clayton Glenn on June 28, 2018 at 7:35 pm
    Trying to get this to work, getting a text sourced from another layer to repeat a given number of times. In this case 5.
    Beginnings work
    s = “”;
    for (i= 1;i <= 5;i++) s +=”source from other layer“;
    s
    For a layer named layer name I am trying to get it to replacy the “source from other layer“;
    Using a pickwhip from the chosen layer, EXAMPLE with live type,
    thisComp.layer(“EXAMPLE“).text.sourceText
    It doesn’t seem to see it as a source and returns that it is expecting a ;
    Any ideas? Many thanks for the time.
    Walter Soyka replied 8 years, 2 months ago 3 Members · 3 Replies
  • Clayton Glenn
    June 28, 2018 at 9:15 pm
    This may be better suited in After Effects Scripts forum… Apologies, I’m figuring out the forums here.
    Best wishes,
    Saving the world one pixel at a time.
  • Kalleheikki Kannisto
    June 29, 2018 at 5:26 am
    [Clayton Glenn] “and returns that it is expecting a ;”
    This seems to indicate you’re missing a “;” at the end of that line.
    Senior Graphic Designer
  • Walter Soyka
    June 29, 2018 at 9:38 am
    This works exactly as expected:
    s = "";
    for (i= 1;i <= 5;i++) s += thisComp.layer("EXAMPLE").text.sourceText;
    s
    If you’re still having trouble, please copy and paste the code you have that isn’t working.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
