Activity Forums Adobe After Effects Repeating Layer
  • Repeating Layer
    Posted by Rcmsantos on August 11, 2005 at 12:31 pm
    Is there a effect in AE that could repeat dozens of times the content of a layer in a similar way as photoshop does with the offset filter?
    Serge Hamad replied 21 years, 1 month ago 5 Members · 6 Replies
  • Aharon Rabinowitz
    August 11, 2005 at 1:28 pm
    You can try either:
    -CC Repetile (Stylize)
    -CC Tiler (Distort)
    These are the Cycore Effects that came with your Pro version of AE 6.5 (non-educational). It’s a seperate installer on the CD. Tiler is probably what you want.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Rcmsantos
    August 11, 2005 at 1:46 pm
  • Steve Roberts
    August 11, 2005 at 3:00 pm
    Effect>stylize>motion tile is another option.
    Steve
  • Jim Tierney
    August 11, 2005 at 7:17 pm
    The Smooth Tiler filter in our Anarchy Toolbox does this as well and gives you additional options for seamless blending, rotating, and cropping the image.
    Check out http://www.digitalanarchy.com for more info.
    cheers,
    Jim
    Jim Tierney
    Digital Anarchy
    415-586-8434
  • Rcmsantos
    August 12, 2005 at 3:00 am
    Thanks for your help.
    The filters you have indicated (I’ haven’t try those of Digital Anarchy) do the job pretty well but they make an patterned environment. The problem is that I’m trying to animate a group of some fairies and I would like to give them a more realist movement and positionning. So, is there a way of minimaze these grid aspect and giving the footage being cloned a position more arbitary?
    A big thanks to you all.
  • Serge Hamad
    August 12, 2005 at 3:33 am
    It’s sounds to me that you should use a Particle Generator (Foam, P.Playground, Trapcode Particullar)
    with your “fairies” as a custom particle.
    Salut.
    Serge
