Activity Forums Maxon Cinema 4D Repeating keyframes
  • Repeating keyframes
    Posted by Jack Cook on December 12, 2012 at 7:17 pm
    I’m using version 14.025. I’m animating a propeller rotor to rotate constantly. I keyframed one second’s worth of rotation (0 to 360 degrees – it’s a slow rotating propeller) and then in the Timeline I chose Funcitons>Track After>Repeat After. The keyframed second of animation repeats once only then stops. I want it to continue indefinitely. Previously I had done this very same thing in ver. 12 and it worked fine. What’s the difference here? Is there a hidden repeat setting I can’t find? The Help doesn’t shed any light on it. How can I make it keep repeating?
    thanks,
    Jack
    Jack Cook replied 13 years, 9 months ago 1 Member · 1 Reply
  • Jack Cook
    December 12, 2012 at 7:26 pm
    OK, I think I found it. They’ve separated out the repetitions from the command and now you have to set the number of repetitions in a separate window in the Attributes manager. It tells that in the Help, but it doesn’t say where it is. I stumbled upon it.
    Jack
