Activity Forums VEGAS Pro Repeating chapters
  • Repeating chapters
    Posted by Angelo Caruso on September 29, 2007 at 12:10 am
    Hello to all,
    I cannot find the parameter in DVDA3 which at the end of a chapter, repeat until a new chapter is chosen. Any help is appricated. Thank you for your time.
    Sincerely,
    Angelo
    Angelo Caruso replied 18 years, 12 months ago 2 Members · 6 Replies
  • Edward Troxel
    September 29, 2007 at 12:44 am
    Look for “End Action”
    Edward Troxel
    JETDV Scripts
  • Angelo Caruso
    September 29, 2007 at 2:49 am
    Hello Sir,
    End action in DVDA is for menus only I belive. You have hold, link & loop. It’s not looping the chapters. I would like the user to select a chapter point from the menu and then It will loop until another chapter is selected. Thank you for your help. How about a script command in DVDA4?
    Angelo
  • Edward Troxel
    September 29, 2007 at 11:41 am
    End Action works for chapters too.
    Edward Troxel
    JETDV Scripts
  • Angelo Caruso
    September 30, 2007 at 11:52 pm
    Hello Sir,
    Please excuse my ignorance. I can’t seem to do it. I created my movie in Vegas with 5 chapters. Then, I brought it into DVDA. I then created a scene selection menu. On the menus, I set the end action to loop because I am using a custom vido\sound animation. I then select the movie file in the project overview window but the end actins are to link when a movie is finshed playing or to stop altogether. I just don’t see what I am missing to get the chapters to self loop. Thank you again for your help & continued patience with me.
    Sincerely,
    Angelo Caruso
  • Edward Troxel
    October 1, 2007 at 1:27 am
    If you want the chapters to indivdually loop, you’ll have to add the video again, set the in AND out points, and then set the “end action” to loop.
    If I want individual chapters to loop, I generally create each one as individual files and then set the individual file to loop. But you then have issues if you want to create a “Play All” function.
    Edward Troxel
    JETDV Scripts
  • Angelo Caruso
    October 1, 2007 at 1:52 am
    Hello Sir,
    Thank you again for your help.
