Activity Forums Adobe After Effects Repeater and Video Layer?
  • Repeater and Video Layer?
    Posted by Corey Whitley on October 24, 2008 at 6:59 pm
    Is there a way to add the repeater to a video layer, just as you would a shape layer? Or is it possible to change a video layer to a shape layer, or null the video layer to the shape layers movement and copies? Does this make sense?
    Thanks.
    Corey Whitley
    Andrew Baker replied 13 years, 7 months ago 3 Members · 2 Replies
  • Roland R. kahlenberg
    October 24, 2008 at 7:43 pm
    Short Answer:NO
    Echo may do what you want. If that doesn’t work for you then look at Trapcode’s Echospace.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Andrew Baker
    February 19, 2013 at 5:59 pm
    There are a few options to doing that, some cost more than others, a free version that isn’t quite developed but works is called layer repeater script by Paul Tuersley at aeenhance.
    Found here: https://aenhancers.com/viewtopic.php?f=3&t=1014
    If you don’t like any of those options, then you can try playing with Motion tile and CC RepeTile under stylize.
