Activity › Forums › Avid Media Composer › Repeated frames in edited CineFrame 24 footage
Posted by Zach Worden on June 23, 2015 at 4:57 amI’m trying to fix a dropped frame issue in the final edit of a documentary shot on a Sony Z1U in CineFrame 24 and edited in Avid Media Composer. Every 5th frame is a repeat of the frame before it. Any ideas on possible solutions would be greatly appreciated.
Shane Ross replied 11 years, 2 months ago 4 Members · 4 Replies -
Trevor Asquerthian
June 23, 2015 at 7:29 pmI’m in Pal land, where we mostly just deal with 25 frames a second
Are your project settings 24p?
Is there a motion adapter on each clip?
Is the audio in sync with the stuttering pictures?
Is the pull down definitely not visible on the raw camera files?
AEscripts have a duplicate frame remover script for After Effects but that’s take a long time to process and you would have to speed up the audio to compensate
Good luck with that
Shane Ross
June 23, 2015 at 7:32 pmAre you in a 29.97 project and timeline? I know that older Sony’s didn’t do 24p properly…didn’t have it in an interlaced 29.97 file, with pulldown added. Some had settings that shot 24p in a 29.97p stream…thus causing the repeated frames.
That’s burned into the file..
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Andrew Kimery
June 24, 2015 at 5:46 pm[Shane Ross] “Are you in a 29.97 project and timeline? I know that older Sony’s didn’t do 24p properly…didn’t have it in an interlaced 29.97 file, with pulldown added. Some had settings that shot 24p in a 29.97p stream…thus causing the repeated frames.”
Yeah, the CF modes on the early Sony HDV cameras were an attempt to mimic the 24p ‘look’, not actual 24p recording.
For those interested in an in depth explanation Adam Wilt did a nice write up on it years ago.
https://www.adamwilt.com/HDV/cineframe.html
Shane Ross
June 24, 2015 at 5:48 pmThought so. I had a project come to me in online shot like that, and it was a pain. Had to explain to the network that it was how the camera shot the footage, and that they’d have to live with the odd cadence. And said we’d never use that setting again.
Shane
Little Frog Post
