Activity Forums Adobe After Effects Expressions Repeat sourcetext from another layer
  • Repeat sourcetext from another layer
    Posted by Gray Wilcox on October 3, 2022 at 4:03 pm
    Hello! I’ve been trying to use this expression to repeat source text from another layer:
    My goal: to use the sourcetext from a main Build Comp and repeat it in X & Y using the following formula:
    the original:
    X = effect(“X”)(“Slider”);
    Y = effect(“Y”)(“Slider”);
    (repeat(X) + “\n”).repeat(Y)
    and here’s my attempt:
    my abomination:
    comp(“Build Comp”).layer(“ARTIST”).text.sourceText.repeat(X) + (“\n”).repeat(Y);
    I’d also like to add a space between the repeated words, if possible.
    Can anyone see where i’m going wrong? With my above abomination code, it will repeat in X but not Y.
    Gray Wilcox replied 3 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 3, 2022 at 4:46 pm
    You just need to move a left paren in the last line, like this:
    (comp("Build Comp").layer("ARTIST").text.sourceText.repeat(X) + "\n").repeat(Y)
  • Gray Wilcox
    October 3, 2022 at 5:22 pm
    Thank you!!!
