Activity › Forums › Apple Final Cut Pro › Repair corrupted project file
Posted by Chris Walker on April 26, 2012 at 9:10 amAny way to repair a corrupted project file other than using the software I’ve seen mentioned? That doesn’t work and I really, really don’t want to lose 30 hrs of editing and start from scratch! No backup project file exists.
Heinrich Dahms replied 12 years ago 15 Members · 22 Replies -
David Battistella
April 26, 2012 at 11:12 amI just went through this very painful exercise.
30 minute film was in jeopardy for a couple of weeks but now it is back on track through much trial and error.
More details are needed, but I would suggest getting in touch with Apple.
What version
What codecs
What effects
How long is the project?
Have you backed up the old versions folder?
Are there any files in the back up folder?David
______________________________
The shortest answer is doing.
Lord Herbert
https://www.davidbattistella.com -
Michael Sanders
April 26, 2012 at 11:28 amIs it me or is anyone else getting seriously worried about the “Fragility” of FCP X projects?
It’s something that really bothers me, the autosaves to the same directory and only when you’ve saved something and no option to save to another disk/folder.
It’s down to the fundamentally disastrous way Apple have decided to separate Events and Projects.
There’s a very obvious fix: Take the sharing and render files out of the project files.
Render files can – by default with maybe an option in prefs. – go on the same disk as the Event. That would mean Project files could then live on the system drive and get backed up by usual back up means.
And as for exports/sharing: Well ask us where to put them! Its a hangover from iMovie and pro’s really don’t need to be hand held with this stuff.
Make projects a filetype not a folder.
Give us back autosave to another location.
I regularly shoot and edit projects that are time critical (be it broadcast news or up to wire financial corporates) and to be honest not having the safety net makes me shy away from using X on these projects.
If I can’t be up and running again in minutes from a hard drive crash or project corruption I’m not happy.
It’s a pity because the irony is for most of those projects X would be much quicker than 7 but I can’t risk it.
Michael Sanders
London Based DP/Editor -
David Battistella
April 26, 2012 at 1:14 pmGreat Idea.
Maybe submit that as a feature request to Apple.
I think a bit more control over where things are and how the “autosave is handled” would be welcomed by many pros. Its a part of our work, something we a just used to.
David
Lord Herbert
Eric Santiago
April 26, 2012 at 1:14 pmIts back to old school folks.
After final, end of day, heck even during editing, I would shut down FCPX and copy a version off to another drive.
Thats how it was for me back in the day with most of my work (3D, Motion and Finishing).
Ive had one project corrupt and it was back in June.
Never again after that, call me lucky I guess. -
David Battistella
April 26, 2012 at 1:51 pmIt’s true Eric.
One corrupt project file makes you want to save stuff off to other locations at every break in the day.
David
Lord Herbert
Eric Santiago
April 26, 2012 at 3:53 pmI also has Dantz Restrospect running (years ago) every hour backing up Maya. Max, After Effects and others plus their resources to another server.
Now that we’re running everything off XServes, I only have to do that with Avid MC and FCPX files. -
Chris Walker
April 26, 2012 at 4:13 pmYour reply gives me hope. No backup folder since I had not yet updated to 10.0.4. All render files and old versions backed up. It’s about 90 min long and not hard to edit, but 30 hours wasted! Will contact Apple.
Bill Davis
April 26, 2012 at 6:59 pmIf you’re in a shared storage or multi-user environ with critical work on the line, then backups obviously need to be managed very carefully.
For the single seat user, just slap a drive on the system and let Time Machine mirror the state of your Event and Project libraries on a regular basis. Done.
Personally, I haven’t lost a single project in nearly a year of working with X and that one was in V1.2 and I was able to recover my TimeMachine clean copy and go back to work in about 10 minutes.
There’s a”Nancy Grace” syndrome at work here, I think. Kidnappings have always happened. But for decades, they were perceived as rare and distant. Now they’re on TV persistently with essentially TV shows who’s ratings sink and swim with the broadcast of that kind of content so there’s a heightened sense that it’s a much more real possibility than it really is for those not in the general class of custody disputes and other risk factors.
When you hear a few isolated examples of bad stuff happening – just note it, maybe take some action if it’s not too expensive or troublesome – and move along.
Only when these boards fill up with large swaths of crash reports or problems – is it time to worry, IMO.
“Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
Michael Sanders
April 30, 2012 at 8:06 am[Bill Davis] “For the single seat user, just slap a drive on the system and let Time Machine mirror the state of your Event and Project libraries on a regular basis. Done.
Personally, I haven’t lost a single project in nearly a year of working with X and that one was in V1.2 and I was able to recover my TimeMachine clean copy and go back to work in about 10 minutes.”
But time machine is only does hourly backups. I don’t know about you, but in my edits a lot can change in an hour, hell I’ve done edits that last shorter than an hour!
Michael Sanders
Bill Davis
April 30, 2012 at 11:03 pmYou do realize that since 10.0.3, X has maintained a 15 minute “Backup” auto folder and if you crash for any reason, the program will revert to that. So it’s pretty difficult to lose more than that unless you do something really truly distractive like make huge changes and then go past the next auto-save time increment?
Just saying.
