Activity Forums Adobe After Effects Reorienting the axis of a 3D layer
  • Reorienting the axis of a 3D layer
    Posted by Steven Bump on July 22, 2005 at 6:39 pm
    I have rotated a 3D layer 90 degrees on X, and want to reorient the axis back to 0/0/0.
    In 3D apps, this is a simple thing – but I’m having trouble figuring it out in 6.5…
    Steven Bump replied 21 years, 2 months ago 2 Members · 3 Replies
  • Yoondo
    July 23, 2005 at 1:55 am
    You need to open the tranform properties on the 3d layer and click on reset.
  • Steven Bump
    July 25, 2005 at 1:31 pm
    Thanks for the reply – however I believe I did not state my question properly…
    I have rotated the 3d layer -90 on z, but want to reorient the layer axis to 0/0/0, not as it is currently (0/0/-90). In my 3D apps, this is done easily (in Softimage, you simply ‘freeze’ the object orientation and the -90 on z becomes 0 – leaving the object re-oriented and the axis reset to 0/0/0)
    I’m having difficulty using the Image Lounge plug in ‘Real Shadows’ – it is placing the start, end and angle settings incorrectly on my rotated layer and my shadows are not ‘behaving’ properly. Again, thanks for any help.
    -sbump@websterdg.com
  • Steven Bump
    July 26, 2005 at 1:35 pm
    Never mind – I just need to pre-comp the layer then apply ‘Real Shadows’ to that and I’m good to go… thanks for your help.
