Activity Forums Adobe After Effects rengenerating limbs with a displacement map?
  • rengenerating limbs with a displacement map?
    Posted by Afrancis on May 10, 2008 at 9:06 pm
    Hi i just saw the tutorial for underskin bugs using a displacement map. I was wondering if i had a foot or hand shaped mask would i be able to create a limbe effect growing out of the body? so basically instead of bugs crawling underskin, a new limb shape would appear in one place and grow bigger?
    Roland R. kahlenberg replied 18 years, 4 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    May 11, 2008 at 12:44 am
    It’s certainly doable using ther same technique but there will be limits as AE is a 2D application. If you keep this is mind when you visualize the effect, you will have a better idea if AE will be able to pull it off or to go to a 3D applicatio nshich is what most professionals use for such effects.
    Cheers
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
