Activity Forums Adobe After Effects Renders look washed out via Kona
  • Renders look washed out via Kona
    Posted by Bob Pierce on August 13, 2008 at 12:12 pm
    Hey Everyone,
    I’m working with a Kona LHE, DVCPRO HD 720 p60. My renders out of AE are looking washed out. I’ve got color management on, set to 8 bit, HDTV (rec 709).
    Out of final cut, I export out a clip with color bars. I bring the clip into ae and set to interpret footage HDTV (rec 709). I render it out with the native codec, DVCPRO HD, 720 p60, drop the render into final cut and it looks totally washed out (on the monitor, via the kona). I’ve fooled around with all kinds of other color management settings to to avail. Any suggestions would be appreciated.
    Bob Pierce
    Mac Pro 2.66 – 8GB memory – Mac OS 10.5.2 – Quicktime 7.4.5 –
    Mac Book Pro 2.33 Duo –
    FC Studio 2 (Final Cut 6.0.3) – Kona Lhe
    Adobe Production Suite CS3 –
    Sony Multiformat 14″ – Panasonic 42″ Plasma –
    Ikegami HLDV7 – PVW EX-1
    Bob Pierce replied 18 years ago 2 Members · 3 Replies
  • Bob Pierce
    August 14, 2008 at 12:42 pm
    Thanks, Dave
    Yep, that’s what they’re set for. The rendered movies play back washed out in Final Cut, whereas the original footage (color bars) that hasn’t passed through AE looks fine. Any other suggestions out there? Am I the only one with this problem?
    Thanks you!
    Bob
  • Jack Leto
    August 17, 2008 at 5:35 am
    have you tried the Animation codec?
    MOTIONOLOGIST
  • Bob Pierce
    August 18, 2008 at 10:50 pm
    Yes, I did try that – or at least I tried rendering out uncompressed 8 bit, which showed the same messed up gamma. I also tried exporting as uncompressed out of fcp, then rendering uncompressed out of AE for the same effect. So I guess I can remove the codec as the culprit. Others have had this problem and posted about it here, but none have posted their solution.
    Bob
