Activity Forums Adobe After Effects Renders failing at frame 123
  • Greg Digenti
    October 6, 2011 at 5:16 am
    Thanks Walter!!!
    I was up to date on my updates, so I tried rendering without sound and it worked! Now I knew the problem had something to do with my sound export settings, I just had to figure out which one was throwing the monkey wrench into this thing.
    –Codec? Nope. All of them failed.
    –Stereo vs mono? Nope, both failed.
    — Can you believe that changing the quality from 16kHz to 22kHz fixed it?? Yep. That was the problem.
    I was trying to save a little space by lowering the quality, but for some reason rendering lossless with 16kHz sound killed any render over 400 frames at frame 123 exactly. Weird!
    Anyway, thanks again for the help.
    Greg
  • Sam Simon
    December 8, 2011 at 1:55 pm
    I’m having the same issue using the H.264 preset. But no matter what kbs setting I use for audio it always errors out at the same point. I tried rendering out just the the video and of course that works. And rendering it using the Quicktime preset .mov h.246 codec works fine, but it’s just that those are such big files. If anyone has any additional fixes for this issue please let me know.
Page 2 of 2
